It is currently Wed Jun 25, 2025 12:28 pm
PostPosted: Tue May 09, 2006 3:20 am
On the guitar that I posted pics of the other day, I have a crack in the lacquer about 1 to 1.5 inches long on the top in the lower bout area. I assume that it got bumped or something during our recent move, at least I didn't notice it before the move.
Question is, how does one go about repairing this type of thing? I thought about using a fine brush and applying a little lacquer thinner there to see if it would melt together. I hate to spray the whole top cause it's a pain to buff out around the bridge and FB.
Any help would be appreciated.
PostPosted: Tue May 09, 2006 6:51 am
Bump.
PostPosted: Tue May 09, 2006 7:06 am
I would use some butyl cellasolve with a fine brush.It melts lacquer very well.Then wet sand and buff it in. As you said,thinner should work .This stuff is just a bit stronger.
PostPosted: Tue May 09, 2006 7:20 am
Thanks Dave! I don't have any butyl cellusolve around and was trying to avoid another Stew Mac order for a month or two.
Maybe I'll just try it with the thinner and see if that works out ok.
PostPosted: Tue May 09, 2006 7:26 am
Hey Dave, I just checked at Stew mac and it looks like they don't carry it anymore. Probably wasn't selling enough I suppose.Anyways ,good luck with your repair.
PostPosted: Tue May 09, 2006 7:40 am
Thanks bud! If you hear loud screams coming from NW of you you'll know it didn't work out as expected.
PostPosted: Tue May 09, 2006 7:45 am
worst comes to worst you can sand back and re-coat that area. Nitro will burn in just fine
PostPosted: Tue May 09, 2006 7:49 am
Thanks Michael! I figured if nothing else works I would try that. Just trying to avoid making any bigger mess of it than I have to.
PostPosted: Tue May 09, 2006 8:26 am
Ntiro will melt into previsouly sprayed areas, but dont bother rubbing ti out for a while, like 6 months. The new stuff will be way softer than the original for a while and if you only let it cure for 3-4 weeks then flat sand and buff I GUARANTEE it will sink, leave a witness line of sorts and look like a repaired area. I stripped and redid two backs because its the only way to get it right IMO.
PostPosted: Tue May 09, 2006 9:12 am
Thanks for the info guys!
Todd, did you spray some of the Tamiya into a cup or something and brush it on?
PostPosted: Tue May 09, 2006 12:22 pm
First name: Rich
Last Name: Barbera
City: Bay Area
Dave,
Here's a bit on Nitro cracks that's covered in Frets.com if you haven't already seen it...
http://www.frets.com/FRETSPages/Luthier/Technique/Finish/Lac quer/CheckRepair/checkfill.html
Rich
PostPosted: Tue May 09, 2006 11:59 pm
Thanks for the ideas Todd and Rich!
